Changing the default setup in Cam
jimmy.haddersPKDBD
jimmy.haddersPKDBD
Hi, iv'e been searching for a solution to this for i think at least a week now and i just can't find one.
I do a lot of different setups when i do CAM operations and as default i use Model box point and not Stock Box point which is the default,
so for every setup i have to change this, and yesterday i kind of went nuts since i had 30 different setups to make...
Is there some way to change the default value in the setups like you can do for separate operations? like make default?
HughesTooling
After setting up how you want setup, go to the Post Process tab, right click one of the input fields and select Make All Default.
Mark
Mark Hughes
Owner, Hughes Tooling
jimmy.haddersPKDBD
Ahh, there it was! Thank you very much, that makes sense in it's own now that i think about it 🙂
RandyKopf
Thanks Mark for this tip!!!
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
