changing default packing size
woorijung
woorijung
hi, we userd to Sketchup and changed to Fusion 360 recently and we are enjoying very much with Fusion 360 amazing features.
In woodworking, we use 4' X 8' sheets of plywood (1220mm x 2440mm) and we have to change this value to 1220 x 2440 every time we nesting.
Is there any possible way to change this value set to default 4' x 8' (1220mmx2440mm) in the near future updates?
also, we have to check Include stock every time when we first do nest study. that would be much better if this can be save a user default.
Have a nice day!
matty.fuller
Packaging size and all other material/packaging settings can be stored in presets, and you can set a default preset. Takes a bit of time to set up but then will have you nesting in seconds every time after that, very powerful.
SOUL_CNC
thanks for the information. matty!!!
