Changed behavior in 3D adaptive
jagSJMV8
jagSJMV8
We are milling a part where the 3D adaptive behaves real odd. The protrusions on top are 5mm but 3D adaptive only does side milling, and in the mills 13 down from the facing rather than the 5mm
What are we doing wrong when the machining ignores part of the area. We lost CAM libraries and have strange behavior since the last update.
I have made a mockup of the part
programming2C78B
It'll be a combination of having Flat Area Detection on and minimum/fine stepdown value.
Please click "Accept Solution" if what I wrote solved your issue!
jagSJMV8
Removing Flat Area detection does not change things.
We always run flat area detection to make sure we don't break tools in subsequent processes.
dzimnicki
set Minimum Axial Engagement to 0
and Top Height to Stock top
DarthBane55
I very rarely use flat area detection, because it often results in wasted time cutting a level that does not need to be cut for the whole part (say there is a small island in 1 area of the part, it will cut at that Z level the entire part).  I prefer to create more operation, for each Z level, that way it does not cut something 0.1" deep on the whole part.  Depending on the part, this can save a lot of time.  But, that does not solve your issue... sorry... just thought I've give my 2 cents, for me, flat area detection  is in general pretty bad for efficiency.
jagSJMV8
Thanks!
We use the machine for 1-2 parts per week so for us it is more about
flexibility and not braking stuff than efficiency.
jagSJMV8
Great Thanks!
Anywhere that I can read about the logic, because I get choked time after time thinking I understand what Fusion is supposed to do and how to machine the areas we want to machine?
