Change to simulation?
HughesTooling
Consultant Consultant
HughesTooling
In the past if you ran a simulation to the end then clicked the play button again it would start the simulation again with the original stock. Now if I do that the stock remains as the finished part, is that an intended change\improvement? Same problem if you click the go to previous operation.
Mark Hughes
Owner, Hughes Tooling
ktorokU233T
@HughesTooling
Check here in the sim control...
HughesTooling
@ktorokU233T Must have click that by mistake! Didn't know that was an option. Edit. Just noticed it's the same on 2 PCs on different accounts so I guess set by an update.
Mark Hughes
seth.madore
That's been in the software for a fair bit of time (I think January release). Not sure that we did anything to change the default settings 🤔
Seth Madore
HughesTooling
I had noticed it for quite a while but not that big a problem so I didn't ask before. I was working on some turning setups yesterday and you generally need a slower simulation compared to milling or it's finished before you can blink! So that's when I thought I'd ask. There was an update a couple of months ago that reset all my defaults on both PCs at work and my laptop so maybe that's when it changed.
Mark Hughes
