chamfer with ball mill inside holes intersection
rotzetterdanick
rotzetterdanick
I'm trying to chamfer thoses edges inside the two holes with a ball mill. The first operation should work like this, but not able to programm the second one properly in "radial".
See attached .f3d folder for details.
Has somebody a solution?
If you read description of how Trace strategy works, you can see that two scenarios cannot be accommodated by simply selecting edge of a hole.
For radial orientation, you would have to construct drive curve that is in sink with how Trace works but why do that when you can model chamfer and use Flow instead.
