Chamfer milling a countersink ?
jkesecker76
jkesecker76
So as the title says I'm trying to mill a countersink with a chamfer mill and can't get the result I need. The flutes are smaller than to depth of the countersink. I thought you could do this in previous versions with a contour doing 2 or more step downs? Any help?
programming2C78B
https://www.youtube.com/watch?v=0ZSMY4G0mM0&ab_channel=NYCCNC
Please click "Accept Solution" if what I wrote solved your issue!
jkesecker76
Thanks for the link that channel always seems to have a answer.
