Cant verify stock
Cant verify stock
mike_a_oswald
Cant verify stock
mike_a_oswald
When I add a dovetail to a part for workholding. When I go to the second setup, and click continue rest machine from previous setup,  it gives me "cannot verify stock for rest machining". Does anyone know how to fix this?
seth.madore
Is it possible that you've selected the entire component for your Model in your second setup?
Could you share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
mike_a_oswald
No.  I have made sure I have the 2 bodies selected.
mike_a_oswald
I made a quick example. I will see if I can post it.
seth.madore
Setups and Rest Machining does not work with multiple bodies or components. You can't have a body and a component selected, or multiple bodies or multiple components. However, you can have one Component that contains multiple bodies, as long as you select only that component.
Seth Madore
mike_a_oswald
If I expand the Models tab in the tree, and click on the model name for the model in the setup page, instead of the 2 bodies, then it works.
seth.madore
Single body, right, not multiple?
Seth Madore
