cant see sketch in manufacture`
magpiemachining
Message 1 of 8
magpiemachining
hi folks, I have a cutter with a shorter flute than the desired length of the cut.  Its 30 degree. I tried to do this in 2 step as always was successful before with other systems. fusion doesn't take into account the radius when using negative stock. So this don't work. it subtracts the radius also  and in this case making the corner sharp. Anyone find a way to machine an angle in multiple steps using  a body or component? The other issue is I drew a sketch and trigged out the triangle to get the square dimension at  1/2 the depth. but now I c ant see the sketch in manufacture. I can blink the eye in design and see it  but it won't blink in manufacturing  or stay open.
Replies (7)
Message 2 of 8
seth.madore
Do you have Sync Visibility turned on, it's found at the lower toolbar
Seth Madore
Message 3 of 8
I can see all your sketches in MFG workspace, right click on CAM Ruth and "ShowHide".
2021-01-27 08_28_09-Autodesk Fusion 360.png2021-01-26 17_59_41-Autodesk Fusion 360.png
Message 4 of 8
magpiemachining
if icxlick it work but then closes.it dosnt stay open. imon a mac. shoulndt haveany thing to do withit.
Message 5 of 8
magpiemachining
I don't see where that is.
Message 6 of 8
seth.madore
@magpiemachining at the bottom toolbar:
Seth Madore
Message 7 of 8
magpiemachining
hi Seth, it was on already. I still couldn't open any eye. at all. only in design. when I flip to man the shut off. I made another sketch. nothing again. she thing but I forgot to turn the sync back on. it showed me the sketch. I never new that existed. thanx. any help with the angle issue?
Message 8 of 8
magpiemachining
correction, when I select the sketch in a set up the sketch is gone again.
