Cant open new tool library system error
Carbidecnc
Message 1 of 13
Carbidecnc
Hi I can't seem to open new tool library please help see attache screen shot
Replies (12)
Message 2 of 13
seth.madore
Hmm, I'm not seeing that on my Mac. What generation do you have, and what OS?
Seth Madore
Message 3 of 13
Carbidecnc
Hi Seth Catalina 10.15.4
Message 4 of 13
jeff.pek
Can you tell us which Preview Features you have enabled in Preferences?
  Jeff
Message 5 of 13
macmanpb
Here the same error. But a little bit harder. If i click on "Send Report" in the system error message, fusion360 crashes.
I clicked "Send Report" twice the time and hopefully had send anything before fusion360 crashes.
Message 6 of 13
Carbidecnc
Hi Jeff
See attached
Message 7 of 13
jeff.pek
If you temporarily disable the Tool Library preview, you'll be able to go again. Hopefully the folks familiar with this area can engage with you soon.
Jeff
Message 8 of 13
obrienm
Hi @Carbidecnc and @macmanpb ,
I'm part of the development team responsible for the new Tool Library. Unfortunately we haven't received the error reports from you. Something may be wrong with our reporting system in addition to causing the system error you're seeing. We have tested the Tool Library on own machines running macOS Catalina using the same preview options and haven't seen this problem.
I'd like to gather as much data as possible from you in order to investigate this issue. If you could follow this guide to gather your graphic diagnostics, as well as export any local or cloud tool libraries you may have (using the old tool library), and send that all to me in a private message, we'll be able to start narrowing down the potential causes.
Mark O'Brien
Senior Software Engineer
Message 9 of 13
macmanpb
Hi obrienm, it is not possible to add attachments to private messages. How we should add the exported tool libraries?
Message 10 of 13
Carbidecnc
[GPU Information]
GPU Device: Intel(R) HD Graphics Family
GPU RAM: 112 MB (Integrated card)
GPU Driver API: DirectX 9.0
GPU Driver Version: 20.19.15.4568
GPU Driver Date: 01/09/2017
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
Message 11 of 13
obrienm
My mistake, I'll message you an email address to send them to.
Mark O'Brien
Message 12 of 13
obrienm
Just a quick update to say we've found the cause of this system error, thanks to your help.
Unfortunately there's no known workaround at the moment except to use the old Tool Library.
Good that we discovered this before releasing the new Tool Library to everyone though!
We'll make fixing this a priority.
Mark O'Brien
Message 13 of 13
obrienm
Hi @Carbidecnc , @macmanpb ,
Just letting you know that today's Fusion release contains a fix for this issue.
Mark O'Brien
