Hi all,
I'm new in manufacturing and have bought a simple CNC router to learn. My goal is to do the fillet by a single path by a specified tool, instead of multiple pathways by ball end.
Please see attached picture. Two questions.
1. How should I set up this mill? By the way, what is the proper name of such mills? Cannot set up it as a radius mill.
2. Because this mill has a dull tip, how should I set up fusion to do a fillet? I think I should use a trace operation and select a curve, but what is next? Do I need to set the height -6 mm because of a tip? Should I set the axial offset of half a tool diameter (3.175/2) or half the tool diameter (10/2) or the bottom part of it (5.5 / 2)
Thanks in advance
Roman
