Message 1 of 11
I work in a shop with multiple machines. Some of the machines have 10k rpm spindles and some have 18k rpm spindles. What I want to do is to be able to just change the machine definition of a setup and then have the spindle speeds be limited by the max speed in the kinematics and feed adjusted accordingly. As it stands it will give a warning for each toolpath that exceeds the limit, but that still requires me to go through and edit each affected toolpath manually.
It seems like it should be a really obvious and easy thing to do. I just need a reference parameter for the setup's machine definition max spindle speed, but I can't find it.
