Can the nest feature break up one large component onto multiple sheets?
Hi everyone,
I hope you're doing well, please excuse my ignorance, project file is uploaded below. I often need to create very large shapes utilizing multiple sheets of plywood. The one that I'm working on now is fairly simple, an octagon where each side is 8 ft. in length; however, the shapes are often a lot more complicated. I've used the Nest feature to nest multiple smaller pieces onto one sheet of plywood, but what I'd really like to be able to do is break up a much larger shape into smaller pieces which can each fit on one 4x8 ft sheet, and have fusion calculate the optimal layout in order to use as little material as possible. Is there a way to accomplish this? Again, I apologize if I'm missing something obvious, I've been researching all morning and haven't found a solution. Thanks so much for your help, let me know if you need any other information.
