Can't use pre-drill entry unless "Keep Tool Down" is enabled?
FrodoLoggins
Advisor Advisor
FrodoLoggins
Why not?
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
oleg.tikhomirov
Hi @FrodoLoggins,
This is by design. Transitions from drill position to cutting paths are considered as part of stay-down moves so "Keep tool down" must be enabled to allow them. Moreover "Maximum stay-down distance" should be big enough. Otherwise operation might fail with the following warning:
Oleg Tikhomirov
Software Engineer
programming2C78B
it has to....that's the (w)hole point of picking a drill point center.
Take a peek at using a Circular toolpath for this feature, you may enjoy the enter/exit at center function.
Please click "Accept Solution" if what I wrote solved your issue!
