Can't post-process "Call Program" from NC-Manual - How to modify PP
Hey,
My postPro is made to CNCRepRap use.
RepRap GCODE for a subroutine calling is M98 Pxxxx.
So far, I use PassThrough and that works really well.
But I wish I could use Fusion 360 CAM features properly and I actually can't post-process "M98 Pxxxx" with 'Call Program' function.
Please, help me to modify my Post-Pro so that I can use this function.
@seth.madore
seth.madore
I would suggest taking a look at the Fanuc post, as that has a lot of work done to implement the M98 sub program calls:
https://cam.autodesk.com/hsmposts?p=fanuc
Seth Madore
Thank You @seth.madore 😀
I found out the right command into the fanuc PP you advised me :
writeBlock(mFormat.format(98), "P" + value);
Then I get inspired by the Post Processor Training Guide to write the following command :
//Called with every ManualNC command
function onManualNC(command, value) {
switch (command) {
case COMMAND_CALL_PROGRAM:
break;
default:
expandManualNC(command, value); // normal processing of Manual NC command
programming2C78B
Hi I'd like to do with this the Haas NGC as well.
Please click "Accept Solution" if what I wrote solved your issue!
