Hi, I took a month break and I came back and it seems like either I'm doing something wrong or there's been some massssssive restrictions put down on the personal use version of Fusion.
I have a file I'm trying to do that has a rough pass and a fine pass with a smaller bit.
It tells me I can't do tool changes in a single file??? So in the free version, my project needs to use the same bit all the way through?? How am I supposed to try out the program to see if I want to eventually subscribe if there's massive limitations that prevent me from using the most basic functions of the program?
It seems like it's not only tool changes, it's simply I can't have more than ONE operation in a single file??? So I need to make like 15 files just to make one simple thing? Isn't this as simple as just combining all the text files into one? Please tell me they didn't tweak it so it refuses to combine the G-Code files because that's not a feature, that's just a time saver theyre taking away. I hope I'm doing something wrong and this isn't the case.
Weirdly, 2 nights ago I was able to make a file with 5 tool changes just fine, so is this a new thing that was put into place on friday?
