Can't get fusion to stop cutting air
stenersonmachine
stenersonmachine
There used to just be a checkbox for this, but it was removed in an update. I don't need it to cut the air through the middle of the bore because there is no material there. I have tried every option and cannot get rid of it.
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Without seeing your file, I suspect that the issue is your "Stock Definition" might be set to "From Setup Stock"?
Seth Madore
stenersonmachine
I ended up making another op where I cut out the bore, but left the proper amount of material, and then selected "from last op" in this operation. And then when I made my CNC file I skipped the first op.
programming2C78B
fyi you can also just disable specific toolpaths from being posted in your NC window.
Please click "Accept Solution" if what I wrote solved your issue!
