Can't Figure This Out: Different Results from Same Operation
If anybody has an idea on this, I'd appreciate feedback:
First, I draw everything in AutoCAD and then XRef into F360 for modeling, usually with little trouble. On this particular project, I have two drawings made from the same file. One comes in at 0,0,0 but the other at Y 12.0", which isn't a problem as I just move it to the right spot. Yes, both drawings have the same units, origin, etc. I'm only mentioning it if it pertains to the real problem:
In the top model, Brace 1, the same sketch is imported on two different planes, and then the ends of the spline curves are dropped down by just grabbing the end and moving by any number of ways, which all work. If you take the model and look at it from the top, the curves aren't exact but that's OK as they are CNC'd and then sanded by hand afterwards - this is just doing the grunt work.
On the lower Brace 2, the right point, furthest from the origin, also moves as expected, but the left point gives me terrible results: the spline curve rotates in odd ways and lands in an odd location.
Two days later and redrawing/reimporting several times, it doesn't work. I've pulled this same trick off many times with no problems...but...
