Can only select bodies in setup model? need to select a surface group
I am finding myself required to reselect some 40 different faces repeatedly for every new operation in a setup. I tried to select the relevant faces in the setup options dialog, but it will only select surface bodies, solid bodies etc. Not selection sets, face groups, nothing else. Also, none of the selection filter options work at all. It frequently selects the component, for instance, instead of the faces that I want. I have to very tediously deselect it by clicking once in just the right place.
Its pretty nuts. Surely this is what the setup model is for? So you don't have to reselect everything every operation. I recall the same problem with hsmworks, which clearly fusion mostly is.
Any ideas on how to get this working?
