Can not open .prt files anymore
emil_gerasimov
emil_gerasimov
Hello guys,
Today when i try to import a .prt  files , the screen stays blank.
I've tried open models that i previously opened , but again, blank "untitled" tab opens.
Is it because of the today's update?
Tnaks in advance
MILL9YNUC
You are not alone, If you change the file type to a stp it will load just fine.
RajkumarIlanchelian
@emil_gerasimov
File - Open for certain file formats are having some issues that we are aware of. in the data panel please use the Upload function and this will get you what you need. We are working to see what is the problem with he File - Open workflow.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
emil_gerasimov
Thanks alot,thanks both you guys, this "upload" workflow option works  fine for me.
I hope you fix this issue soon.
Best regards, Emil.
