CAM Tool Orientation Origin
I have  a CAM model that is essentially a cube with a pocket.  I need to assign the tool orientation origin in the middle of the plane above the pocket.  How do I do this?  There are no corners or anything to use.  Is this even possible?
Thanks!
Steinwerks
Are you using a multiaxis machine (IE with a rotary axis or multiple axes) or are you setting this up for a 3-axis machine? You won't want to use Tool Orientation if it's a 3-axis part, you'll want to make the Setup match your part orientation for CAM.
That said, I would go into the Model workspace and create an offset plane with a sketch point on it located where you want your Work Coordinate System.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
