CAM solid boring tool from Solid model downloaded form Iscar
chris.rouxel88
chris.rouxel88
How can I use this solid model as my cutting tool on the lathe?
https://www.iscar.com/eCatalog/Item.aspx?cat=6403545&fnum=1741&mapp=IS&GFSTYP=M&srch=1
seth.madore
At this point in time, you cannot use the solid model as a cutting tool, unfortunately. Your best bet is to find an insert shape and boring bar that is a close approximation of the actual tool.
That said, we have active work going on at the moment that seeks to address this. It's still a fair bit out, but it's high on our priority list!
Seth Madore
