So I'm back on this sign for a friend and after a few changes am ready to cut it... but I can't get it right - ugh! I've attached a couple of images and can give access to the file if needed (though I'm not certain how best to do that). I didn't try to draw the exact perimeter in Fusion 360; just went with a circle about the same overall size and figured the little bit of air cutting won't amount to much wasted time.
The sign is about a 24" sort of circle ranging from about 3" thick to 4" thick and is a slice from a Pecan tree. This is a piece of one tree cut down to build the new facility and thus has some sentimental value (i.e., it's the only one I have so I need to get it right the first time).
The images are of the actual Pecan slice with the intended letters and symbol overlaid to scale or at least close. I don't have to make the slice a constant thickness so all I have to do is place the top plane level to my CNC table and face it so my plan is to do that with 2D face and a 1.5" flat bottom bit, same one I use to level my spoilboard. My intention was to then use the same 1.5" bit to hog away everything it can around the letters and symbol just to cut machining time to a minimum. However, when I try to set that up in 3D parallel that bit isn't available to me. So the largest bit I have that shows up in that profile is a 1/2" flat bottom end mill or router bit.
In my CAM setup I have tried 2D and 3D pocket, 3D pocket, 3D horizontal, and all work to some extent but none work to completion. Some don't have rest machining to continue from previous operations so the subsequent operations with a smaller bit just takes forever and it will be cutting air most of the time. Some seem to have a lot of collisions regardless of how I changed the settings.
My CNC router is a Saturn Pro 2x4 stress relieved welded steel frame from Fine Line Automation and I designed, sourced, and built everything else. It has a 3Kw water cooled spindle with four 637 oz. in. NEMA 34 motors and I'm running Mach4. I have rapids limited to 750 ipm but it will go much faster. It's a stout machine and as it sits is about 600 lbs. This is my first CNC so I have a lot to learn but am getting up to speed best I can. I offer these specs more to say that it should cut this Pecan slice with no problem except that I can't figure out how to do it within Fusion 360.
So I am at a loss on this... what's my best approach going to be besides carving this by hand? And I REALLY don't want to do this by hand... LOL!
Thanks, guys and gals!
David
David Falkner
