CAM Machining time bug since last update
rengfx
rengfx
Anytime I create a new CAM operation, my machining time will not be displayed until I save, close the file, and reopen the document. Then again ANY new operation will not display machining time despite regenerating etc
Only since the last update, this was not an issue prior. Searched, didn't see any other threads with this specific info
seth.madore
I am seeing the same thing. I will get a ticket logged for this. Thank you for bringing it to our attention, and sorry for the inconvenience.
Seth Madore
rengfx
Thank you thank you
It's still generating the toolpaths accurately at least, and I can run them, just seems like a minor thing with actually displaying the new calc time etc. I've been running all day so no downages but great to see such a fast response!
I just found this as well.  If you right-click on the setup or operation you can select Machining Time and that appears to be accurate.
seth.madore
With that 2.0.5338 update that came through the other day, this problem has been fixed.
Seth Madore
