CAM expression not saving when selecting a different tool
FrodoLoggins
Advisor Advisor
FrodoLoggins
My expression for the tool's cutting feedrate:
Even after hitting "Make Default", the expression is wiped out if I change my tool:
Is there something else I need to do to get the expression to save?
My Setup:
Latest Fusion update
2016 rMBP MacOS 10.15 (19A526h)
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
johnswetz1982
Make default is only for that tool. I think you want "make default for all"
seth.madore
This is incorrect, unfortunately. Any default setting in the toolpath speeds and feeds dialog is null and void next time you start one up. If you want default settings to persist, that needs to be done at the Tool Library level
Seth Madore
