Bug with Arrangements
pcsentinel
pcsentinel
I am having issues with arrangements that loose cohesiveness when a change is made to the design.
File and video attached.
Having laid out arrangements, and named them Board 1..4, if I go back to the design and make a change, then go back to manufacture, the arrangements have lost their names, this means that I then have to rename the arrangements back to their original names and the go back to each setup and reapply the arrangement.
seth.madore
Unfortunately, this is the current behavior. It's certainly less than ideal...
The good news? We've fixed this internally and it will be included in our next major update!
If you're a member of the Insider program, you can access this improvement now. Membership is free, but it does involve an application process. You can apply here: https://feedback.autodesk.com/key/Fusion360Insider
Seth Madore
pcsentinel
Thanks for the info
