Bug in tool management manufacture
lars.olav.tveito
lars.olav.tveito
Found what seems to be a bug. If I go in to the right-mouseclick menu Edit tool on an operation, and change spindle direction, it does not change in the output to the post. If I go via Edit-edit tool, then it changes in the posted result. This happens both for live tools and regular tools. Took me a while to figure this out, and broke a drill bit in the process.
dylan_smith
Hi @lars.olav.tveito,
Can you attach the project and post processor please. I'll report this issue to development.
Dylan Smith
Manufacturing Specialist
lars.olav.tveito
@dylan_smith
Please see enclosed files.
christopher.cooperVHK2N
@lars.olav.tveito This issue has been reported and the task number for your reference is CAM-26597.
I have been looking to replicate the problem through the workflow described this morning with @dylan_smith and I do not get the same outcome. For me the spindle direction changes as expected in the nc code.
I may have interpreted something incorrect so it would be really useful, if you have the time, to attach a screencast.
Chris
Christopher Cooper
Technical Consultant
@christopher.cooperVHK2N and @dylan_smith , I think I've been able to reproduce the problem and I've sent you a video explaining internally so you can take a look.
Michael Grenier
Senior Solution Engineer
lars.olav.tveito
I tried to to  a screencast, but now I was not able to reproduce the error myself consistently on the previous file. I tried on another file with subspindle setup, and then I got the error. Se screencast.
Enclose file with subspindle drilling which you can use for testing.
@lars.olav.tveito Thankyou for taking the time to do this. I can replicate this error now and I have also noticed it does not seem to be consistent. I will ask a developer to look into it.
Christopher Cooper
