Machine is Bridgeport Torq-Cut 22 with DX-32 control.
Post processor is a modified version of the DX-32 post in the Fusion Library, and is attached. The previous mods mostly had to do with G9, and @a.laasW8M6T hooked me up with those mods here: https://forums.autodesk.com/t5/fusion-manufacture-forum/post-processor-g9-formatting-g9p-005/td-p/13...
Now I have found problems with the drilling cycles.
First problem: G83 (deep drilling) outputs only one peck depth.
In the output we get:
G0Z0.1
G83X0.Y0.Z5.1Z1.5F10.4
G80
From the machine manual:
"The format for the deep hole cycle is:
G83X_Y_Z_Z_Z_F_
Where Z_Z_Z_ is the total Z depth, the first peck increment, and subsequent peck increments."
So the output from the post is omitting the third Z value for the 'subsequent peck increments', causing the hole to be drilled in 1.5 in increments all the way down.
*Possible conflict: The pecking depth reduction setting can't be effective since the format listed in the manual allows for an initial peck increment, and then the increment for the rest of the pecks, not a series of smaller and smaller pecks.
Second problem: The feed height is set to 0.020" above the hole top, but the feed actually begins at the retract height with the output code I listed above. So if the counterbore is already done, it cuts air on its way to the hole top. This occurs on G81 (drilling - rapid out) as well. A workaround could be to set the retract height to 0.1" above the hole top instead of stock top in this case, but then if there are a series of holes, the linking moves are too low and would break the drill off in the countebore.
Any help is appreciated. Thank you!
*edited because I messed up the formatting.
