I was doing some tests to see if the geometry created in Fusion is smoother when milling, than the one imported. So i created a sphere in fusion and i imported one from another software which has 65024 triangles.
In the cam workspace they look identical. You can see the polygons on both of them:
but in the render workspace the sphere created in fusion is much smoother:
So my question is: Would the sphere created in fusion be smoother if i mill it on my cnc? Why does it look smoother in the render workspace? Is it just a smoothness effect in this workspace, but when i actually want to mill it it would be faceted like the imported mesh?
I want to know if i should model my geometry in fusion, or another software. Is there any advantage to create the geometry in fusion in regards to milling it on your cnc?
Thanks!
