Boring part with multiple diameters?
GilmaxCNC
GilmaxCNC
I'm trying to bore this part and with 2 diameters. The front of the part is a smaller diameter which will be threaded. When I do a profile finishing pass it just machines the smaller diameter only? How do I get it to machine both?
leo.castellon
Without seeing your file it is hard to diagnose, but from your screen shot, your tool is red, which usually means a collision. Your tool is probably not able to reach the inner larger diameter without colliding with your small entry hole.
LeoC
a.laasW8M6T
Do you have "allow grooving" on in the passes tab?
Allow Radial Grooving should work
