Bore operation, improvements
ole.alex6AK75
Message 1 of 1
ole.alex6AK75
I would love to see 3 changes to the bore operation.
1) Add a separate feed value for the finish operation or adjust so it works in an intuitive way, as of now bore uses the cutting feedrate for boring and the finish operation, often the bore feedrate is very high compared to what one would use for finishing. The ramp feedrate isn't used for bore which seems a little weird as it's basically ramping.
2) An option to stop the retract after roughing and before finishing.
3) To make the finish pass really usefull please add a finish overlap.
This would make using bore a much smoother operation and save some time when programming, right now i have to add a 2D contour to finish after a bore operation due to not being able to specifiy a finish feedrate.
Replies (0)
