body surface of an object to a different body as schema
alain_rogerNVLMR
alain_rogerNVLMR
I have an assembly where 1 object has a body surface that I would like to shape on a different component body as schema.
I already did it in the past  but I forgot how I did it.
so I have a component (a press button - small square and circle in blue) and I would like to "copy the dimensions and the place (in XYZ) to create a simple 2D schema on another component object surface (wide blue rectangle), co I could cut it to make space for the button.
So How can I get the small square dimensions and place (XYZ) to create the same surface but on the wide blue rectangle ?
thx
kacper.suchomski
Hi
Edit the bigger component, create a sketch, project the button geometry, extrude in cut mode, finish editing, add connections between components.
Kacper Suchomski
rosie_lucas1
Hello @alain_rogerNVLMR ,
Did the information provided by @kacper.suchomski help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
