Blend Toolpath Has Small Zig Zags
jonathanBUCVS
jonathanBUCVS
Depending on how I change the tolerance, I am getting some weird little zig-zags in the toolpath, or linked moves that should probably be cut moves. And If I change the tolerance too much, the toolpath blows up a bit. All shown in the attached file.
It would seem that Blend would be the correct toolpath for this operation based on the Fusion thumbnail for the Blend operation. I am open to other suggestions
marcus.toepke
With your T8 tool it looks good in my opinion.
It seems in your zick zag case, it is the size of the tool!
jonathanBUCVS
There is still one small zig zag with the T8 toolpath. Since the part is smooth, I would still consider this an error in the toolpath.
I would also like to address the general case of why this is happening, so I can apply the knowledge to other features. Including both the zig zags and the random parts of the toolpath that change to green lead-lines instead of blue cut lines.
