Blend Strategy : Can't select proper Drive Curves
laurent.vidonne
laurent.vidonne
Hi All,
I'm trying to use the Blend machining strategy to machine the fillet that connects curved surfaces, with a D10 Ball End Mill.
So I first selected the 3 surfaces that make up the fillet for Drive Surfaces, then upper limit of the fillet as a first Drive Curve.
Then the problem arises when I try to select the lower limit of the fillet, as an open curve : I can select the first segment OK, but when I try to click on the 2nd segment,  Fusion always select a bunch of segments, either the 4 segments that surround the 2nd face of the fillet, or segments that go around the fillet and come back at the start of the 1st segment (see picture)
Am I doing something wrong ? Is this a known problem ?
Thank you for your help and advice.
Laurent
Laurent
kacper.suchomski
Hi
How can we check this without the file?
Kacper Suchomski
laurent.vidonne
The problem is that the file is not mine to share.
What can I try / tell you that could help ?
Laurent
kacper.suchomski
You can create a new file that mimics the problem. The problem is the design issue, not the file itself.
Kacper Suchomski
laurent.vidonne
OK, so here is a portion of the original part that shows the same problem :
I'm unable to make a proper selection of the 2nd Drive curve
Laurent
kacper.suchomski
The problem is caused by a small break in the chain.
Failure to identify this break creates a gap, which causes the program to automatically fill in the entire chain.
(view in My Videos)
Kacper Suchomski
laurent.vidonne
Got it, thank you.
As it is the 1st time I'm using this Blend Strategy, I did not think about using zooming to check the continuity of the profile.
Thank you for your help !
Laurent
