Blend: Five issues in one
eerier_bleach0f
eerier_bleach0f
Here's my drive curves:
Here's what Fusion spit out:
Doesn't follow drive curves
Bottom passes are wonky and jagged
Tool kisses the top of the model during every transition
Literally just one lead in/out rad despite specifying otherwise. Those are smooth transitions?
Top pass isn't like the others
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
eerier_bleach0f
The drive curves:
The toolpath:
programming2C78B
tightening your tolerance will get rid of the squiggles.
Please click "Accept Solution" if what I wrote solved your issue!
jonathanBUCVS
I posted a similar issue with zig-zags in my Blend toolpath last week, with no resolution. Playing guess-and-check with the tolerance adjustment does indeed create some better (and some worse) toolpaths, but it didn't eliminate all the wonkiness for my particular application.
CGBenner
@eerier_bleach0f Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Industry Community Manager – Design & Manufacturing
oleg.tikhomirov
Hi @eerier_bleach0f
Could you please attach example parts, so we can look at them? Thanks.
Oleg Tikhomirov
Software Engineer
