blank window instead of tool library on macOS 11.0.1 - big sur
When I'm trying to open the tool library (or any form of it actually: select a tool for a path for example)
I end up with a completely blank window, I can still "blindly" interact with it and select a tool though
Do you know any way to fix this by any chance ?
rasmus.pedersen
Thanks @Anonymous for bringing this up. Have you by any chance enabled the new tool library.
If possible you can disable it as shown on this screenshot to see if that works better for you ?
Rasmus Pedersen
Senior Software Engineer
hello !
I just tried it and YES ! it did fixed my issue !
I can now see my tool library properly !
thanks a bunch
christopher.cooperVHK2N
@Anonymous I am sorry to hear you are experiencing issues with the new tool library. Would you be able to replicate and send me a screencast so I can get the development team to have a look?
Thanks in advance.
Chris
Christopher Cooper
Technical Consultant
gtprototype
New installation on windows 764, getting the blank tool library.  Here's a screencast:
https://autode.sk/30KhiXT
Dale Speakes
prototype technology
jeff.pek
Hi Dale -
I would suggest upgrading your Windows installation. Windows 7 is no longer a supported OS, by Microsoft or Autodesk. It may or may not solve the issue, but at least we'll be in a better position to support you.
Jeff
gtprototype
Thank you Jeff,
At first I thought you were being sarcastic, stating the obvious but then I realized you probably don't use Windows 7 and that you are unaware that there is a persistent warning banner at the top of the work space to keep windows 7 users informed of that very fact.  Better to chuckle at a misunderstanding than flame you -thank God I waited to respond. 🙂
Dale Speakes
