automated testing for post processors?
ginabythebay
ginabythebay
Is there a recommended way to set up automated testing for post processors?
I would like to find a command line way to run my post processor against an intermediate file to verify that I haven't made any changes I did not expect to. I can figure out how to compare the expected output versus the output produced.
Ideally it would be something that I can run under linux, using, e.g. github actions, as well as on the mac and on windows.
In searching around, I ran across this page which implies the existence of a standalone post executable: https://cam.autodesk.com/posts/reference/usage.html but haven't figured out where to find the post executable.
Alternatively, perhaps there is a way to cobble something up with node?
Thanks for any advice or pointers!
a.laasW8M6T
get the fusion post utility for Visual studio code, this will post out a variety of test code and allow you to verify post processor changes, you can even test with actual toolpaths from Fusion too
https://marketplace.visualstudio.com/items?itemName=Autodesk.hsm-post-processor
ginabythebay
Thanks for you reply. I find the visual studio extension useful for many things but I am looking for a way to set up automated testing.
seth.madore
The post executable is found at /user/name/.vscode/extensions/autodesk.hsm-post-processor-x.x.x/res/settings.json
Seth Madore
ginabythebay
That worked on my mac, thank you!
