Auto generated job numbering
hufstedler65
hufstedler65
Is there a way to turn off the auto generated job numbering? In the screenshot below I want both programs to just say "Center drill", I know which program is which with out an extra number but when there is a "(1)" next to a program it throws me off. I used to be able to delete the "(1)" when coping and pasting a program but since the July 23' update I have not been able to remove the "(1)". Any information would be very helpful, thank you.
programming2C78B
Known issue. It's easy enough to ignore.
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
As @programming2C78B says, this is a known issue and you should see better behavior in a future update.
Seth Madore
