As of this morning, I have been unable to successfully generate 3D adaptive tool paths on a model that was working perfectly on Friday of last week. I am cutting electrodes for spark erosion. One aspect of this is re-cutting them after they have been used for roughing. The workflow is as follows:
Produce a manufacturing model of the previous electrode form
Move the body a few mm above the main part to be machined.
Use this model for the stock "from solid"
Generate various tool paths to machine the form.
This has been a workflow that I have used time and time again, but it since this morning it refuses to generate toolpaths for 3D adaptive with rest machining. It get part way through the process and then says the following.
"Invalidated: Generation failed
Error: An unhandled exception occured 0xc0000005."
I don't ideally want to make this file public as it is for tooling for a sensitive project. However wondered if anyone else has noticed issues. I have a large number of dmp files if that is of uses for trouble shooting.
Cheers in advance.
John
