Any idea why this pocket toolpath cuts the round corner?
ltomuta
Advisor Advisor
Message 1 of 12
ltomuta
Project: https://a360.co/3gfIFz6
In this project I have a pocket toolpath which I cannot convince to follow the selected contour and stop going right through the radius.
In the same project, a contour toolpath create as a derived operation from pocket, so having the same selected chain, manages to keep the desired trajectory.
Why and how can I fix the pocket?
Replies (11)
Message 2 of 12
DarthBane55
Sorry, I don't have an answer, but wanted to add to your issue:
While playing with your operation, I added a "stock contour".  The result is seen below, it cuts off any radius, making a straight line between start and end point of every single radius.  Seems like a rather major bug.
Message 3 of 12
Mattxer
My guess would be because that face is on a slight angle and not perpendicular to the wall of those edges and raduis that it is causing some type of issue calculating the toolpath. Try using 3D adaptive instead, it worked fine on my end.
Matt Smith
Software Engineer - MSmithDev - https://msmithdev.com/
CAD/CAM/CNC - Micro Insert Inc. - https://microinsertinc.com/
Message 4 of 12
DarthBane55
Ha! I had not caught that draft angle.  However, this being a 2d operation, shouldn't it be only looking at what you select?  Meaning, if the Z axis is picked from the same face as the pocket profile, I believe it should still work...  no?  Because 2d operation do not look at the solid model.
Message 5 of 12
Mattxer
Not sure exactly why its doing that. I don't use 2D pocket much. My guess is its doing something fishy with that draft angle. Could possibly be a bug. Very strange how it just skips every radius.
Matt Smith
Message 6 of 12
seth.madore
I will first ask; You have your Setup with one Z orientation, but then you are using Tool orientation to reposition that Z. Are you using a rotary axis to access that face properly?
Secondly, is this an imported model? Do you know what the initial file was created in?
Seth Madore
Message 7 of 12
ltomuta
The part (large and more complex) is machined on a 5-axes machine and
eventually I got this "working" by leaving a 2mm radial stock on the pocket
which I then removed with the contour. It just took me a lot of time to try
things out and figure that the contour behaves correctly.
Given the angle of the wall I was expecting some of it will be cut when
finishing the pocket but along the radius, not through it.
The project was started from a STEP, probably exported from SolidWorks.
This bit is just a fragment of it, cut using Fusion's split body.
Message 8 of 12
@ltomuta
Try this procedure:-
1) Design mode, delete the radius
2) use draft to move the two flat walls 2.5 Deg so they are at 90 deg to large area
3) redo the radius and reselect the small shape and regenerate in manufacture, pocket now works
Message 9 of 12
ltomuta
@Anonymous The question is not how to design a more machinable model but rather why the two operations behave so differently with the existing one.
Message 10 of 12
seth.madore
I've logged this as CAM-23755, sorry for the inconvenience this causes.
Seth Madore
Message 11 of 12
daniel_lyall
@ltomuta The problem is that it's on an angle, removing the tool orientation shows this, making it a closed pocket it is fine as well basically the toolpath is violating the toolpath with blowing through the corner not going around it.
Workaround what you did or a 3D toolpath
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 12 of 12
seth.madore
It appears that we may have this fixed internally. We should see that fix in a not-too-distant update 🙂
Seth Madore
