All 3D Tool Paths For Milling Failing After January Update
The.Justin.Gibbons
Message 1 of 10
The.Justin.Gibbons
All my 3D tool paths, both new and old, fail to generate after the January update (the one prior to today).
Updated the distributive cam service to no avail. Anybody else having this problem?
Replies (9)
Message 2 of 10
seth.madore
I am not seeing this, but I'm also not using distributive cam.
Can you share a file, either here or privately?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply.
If the file contains linked component, the links must be broken. If the file cannot be shared due to privacy concerns, you can email me the file: seth dot madore at autodesk dot com
Seth Madore
Message 3 of 10
jeff.pek
We posted an updated Distributed CAM installer yesterday (on cam.autodesk.com/download). This should (I believe) resolve these issues.
Jeff
Message 4 of 10
jeff.pek
Hmm. You seem to indicate you installed that. Can you confirm which version is installed? Can you confirm the jobs are being processed on the machine that you installed that on?
jeff
Message 5 of 10
The.Justin.Gibbons
Getting the files for you. Please Hold...
Message 6 of 10
The.Justin.Gibbons
Thru the task manager I can confirm that initial tool path generation straight up fails, but when I force generation (right click, select generate on tool path) it will 'kinda' generate the path, albeit slowly, but will still show it as failed in the task manager.
Message 7 of 10
jeff.pek
Is this happening only when you use Distributed CAM? What if you disable it (in the Task Manager)?
  Jeff
Message 8 of 10
The.Justin.Gibbons
That seemed to work for the smaller part (all 3d paths generated correctly). My larger one is still showing failed in the task manager for 3d adaptive. Although some of the path does generate.
Message 9 of 10
The.Justin.Gibbons
Distributive CAM version 11.1.0.42533
Message 10 of 10
The.Justin.Gibbons
FIXED! If your using distributive cam, make sure ALL machines are running the updated version Thanks Jeff! Thanks Seth!
