Additive toolpath make circular instead of small straight lines
alaverKUR33
Observer Observer
alaverKUR33
Observer
Observer
Looking to use Fusion additive for some DED slicing before exporting the toolpath out to another program. My part is a simple 5 inch pipe and I would like to get the toolpath as a circular movement about 3 pass steps. Is there any way to do this that isn't just adding parameter passes?
Infill should be a circle path not small straight pass. I am using the generic post processor which I assume doesn't support the G2/G3?
lokesh.kalia
Hello @alaverKUR33 . There may be issues with the post-processing but with regards to the toolpath generation, circular 'infill' passes would only be available if you used multiple Profile passes to, in effect, 'do the infill' for you.
Lokesh Kalia
Senior Manager, Software Development
