Additive Machine and Print Settings Confusing
I've been trying to work with Fusion 360 additive manufacturing to simplify my workflow, and there are a lot of confusing aspects to the way machine and print settings are handled. Not in that I can't figure out what it's doing, but it seems needlessly complicated in some regards while leaving out critical features.
My biggest issue right now is the difference between local and document settings. When you select a local machine or print settings, it copies it to the document. When you're editing settings, the UI does not make it clear if you're editing the "local" settings or the "document" settings. If you edit the local print settings and re-select it for the document, it keeps creating new copies in the document that you can't delete. When you re-select a machine from the library, it sets the print settings back to some default that seems arbitrary and not controlled by the user.
Another is that settings in the print settings also have separate toolbar buttons and windows to control (e.g. supports) that, in my opinion, don't belong in print settings because they're not specific to a material or machine configuration.
The worst I've encountered recently is that sometimes when re-selecting a local print setting, it doesn't seem to reliably always apply to the document. I had a local print setting with nozzle and bed temperature at 200 and 0 deg C, but when I selected it, the "document" copy was at 220 and 0, which I only caught by checking the g-code after post.
I know these are a few different issues that probably belong in different threads, but it seems that additive manufacturing issues are largely burred under the subtractive CAM threads, or get no replies, or aren't taken seriously. I really really really want Fusion 360 additive manufacturing to work, but some fundamental issues with the workflow, reliability, and lack of important features (custom start/end g-code in print settings?) are making this an extremely frustrating process.
