Adding a dial test indicator to tool library
amcfarlen
Message 1 of 8
amcfarlen
I'm just setting up my tool library, and the first thing I wanted to do was add my Haimer test indicator to my tool library, but there doesn't seem to be any option. All the available options are cutters of one sort or another.
I would have presumed that indicating off a workpiece as part of the initial setup of a job would be standard fair, but perhaps I'm missunderstanding something.
As well, I tried to add it just as a milling cutter that would use a manual tool change and when it comes to assigning it a lenght offset (mine is 162.21mm) the dialoge box won't accept this number. Seems it doesn't like the decimal points.
So I'm open to suggestions from the more experienced. Thanks in advance.
Allen R. McFarlen
Barron River Guitars & Ukuleles
Cairns, Australia
27" iMac | 3.1 Ghz Intel Core i5 | 20 Gb ram | OSX Sierra 10.12.6
Replies (7)
Message 2 of 8
Sure, indicating off the work piece to establish your initial zero position is something you need to do first, but that is done before you hit Cycle Start and your program runs.
I have no experience on a machine with a probe that can auto touch-off, but even then I don't know if that is part of your CAM program.
As far as the length offset in the Post Processor tab, Fusion is looking for an integer value (usually the same as your tool number) that it will use with the G43 call's H parameter.  It's not the actual length offset value, it's the index into your machine controller's tool table.  -- hopefully I'm explaining that well enough?
Dave
Message 3 of 8
Steinwerks
So I have to ask: how would you program a setup using a tool that does nothing in the cnc control?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 8
jeff.walters
and how would you program to a point you dont know yet?
Jeff Walters
Senior Support Engineer, CAM
Message 5 of 8
griffew
Hi amcfarlen,
The dial test indicator is normally used when setting up the Fixture Offset Register (WCS) in your machine. You would attach the indicator to your spindle and manually jog the head (or table) to touch a datum position on your part or fixture. You will then save the touch location values into the Fixture Offset Table.  This will become your 'Zero' position, (often G53 location) where your CNC program will access later during runtime.
Here is a good website to help explain the Fisture Offset Register: http://www.hsmworks.com/docs/cncbook/en/#Ch06_MachineAndToolOffsets
So, it is not necessary for you to add the indicator into your tool library in CAM because it is not to be used in a CNC program.
I hope this helps!
Message 6 of 8
Steinwerks
I hope you meant G54, as G53 is machine offset. Smiley Wink
Neal Stein
Find me on:
Message 7 of 8
griffew
Yes! G54.
Thank you for the correction!
Message 8 of 8
amcfarlen
After having a sleep on this, I see that adding the dial test indicator to the Fusion 360 tool tables was a dumb idea.
Yes, it goes into the tool tables on the machine, and working out offsets to other tools from there.
Allen R. McFarlen
Cairns, Australia
