I've got a tapered hole and I would like to be able to include a full retract and pause several times during the operation to remove accumulated swarf at the bottom. Of course I could:
- split the operation into several and use modified top and bottom heights to provide the retraction
- manually edit the G-code to add a retract and pause
- hit the 'RESET' button on the controller, manually jog the Z axis up and then resume at the next line number
All these are fiddly and the first two would need to be modified each time if the underlying CAM operation was changed in any way, e.g. changing feed rate.
Any good ideas out there??
