I am attempting to use the adaptive roughing strategy, to open out a chamber with a part, using a grooving tool with a round insert. However I keep getting the following:-
Feature flags: adaptive-turn-roughing contour2D-select-faces enable-rest-shadow hig-styled-qt import-inventor-cam-data iron-object-states machine-simulation old-pocket-detector setup-sheet-viewer spun-profile-v2 strategy-blend
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\tony\AppData\Local\Temp\Fusion360CAM\1\operation30.ironjob
Debug: Writing jobfile to C:\Users\tony\AppData\Local\Temp\Fusion360CAM\1\operation30.hsm-job
Debug: Using CAM kernel from: C:\Users\tony\AppData\Local\Autodesk\webdeploy\production\4c84784f9b312b4c6ccb78d46529ebb70d7a5a09\Applications\CAM360\camkernel.exe
Error: An unexpected error occurred.
Debug: Autodesk dcamcomponents 1.100.1 pm12518
Autodesk CAM Kernel 3.33.0 (225e2807) x64 STABLE vs2017 225e2807b84a4b28ce245adf9e24bb81f6274a1a 2021/07/13 08:00
Warning: Empty toolpath.
Debug: Total processing time: 62 ms
Debug: Total elapsed time: 159 ms
Invalidated: Generation failed
I have attached the file
Can anyone help regarding this error?
Thanks in advance.
