Ability to set default tolerance when machining?
FusionFan3000
FusionFan3000
Hi all, I couldn't find an answer to this in the forums or a particular setting for this within Fusion360...
By default when I'm setting up machining operations, such as a 2D Pocket, the "Passes" tab always has the Tolerance set to 0.1mm by default. I would prefer it to be 0.01mm by default so I don't have to edit this value every time I'm adding a new machining operation.
Is there a way to make this happen?
If not, can I please request this post be moved to "Feature Requests"?
Thank you!
a.laasW8M6T
Change it to what you want, then click on the tree dots beside the value and set as user default:
FusionFan3000
Oh wow, that simple...woops 😂
Thanks so much!
