Hi guys,
evaluating the capabilities of the Fusion CAM module we're facing the problem that we haven't qutite found the correct milling strategy for our products. We're milling rather big parts - especially compared to the tool lengths. So our milling has to happen with the milling end perpendicular to the surface.
In Fusion the only process I understood to 5-axis mill complex surfaces would be to use swarf. However when processing large surfaces this doesn't make any sense.
So: is there any option to make swarf mill with the tip? (like to turn from tangential to perpendicular milling?)
Or is there any other option to utilize e.g. the 3D-Contour milling with the milling end perpendicular to the surface?
Best regards and thanks,
Nicolas.
