4th axis geometry selection
gdixon7HKS5
gdixon7HKS5
Hi,,
I'm trying to select the geometry of the J slot, I do not want it to go around the front face however if i remove the two 12 degree chamfers you can select the bottom contour fine and it will generate the two J slots, The front face is already finished i just need to machine the slots.
any help would be appreciated.
seth.madore
Press the ALT key, select the first edge. Click it a second time, this opens a new dialog box. Add onto the chain, select the "+" button when done.
Seth Madore
mathew.hutton
Hi @gdixon7HKS5
Can you export your project and attach it to your reply please. Can show you how to select the desired contour edges.
Mat
Mathew Hutton
Manufacturing Specialist
gdixon7HKS5
Thanks for the reply and i can confirm it has worked by pressing the ALT key !! oh how the little things make you smile
regards
Gavin
