4/5 axis machining inside a tapered cylinder - Tool will not stay perpendicular to wall
i am trying to machine the inside of a tapered cylinder using milling toolpasses. The part has veins as shown in the picture.
I want to create a toolpath where the mill is always perpendicular or mostly perpendicular to the wall (+- 10°). Currently I am using a Multi Axis Finishing pass. When I adjust the settings for tilt or lead angle, fusion is not able to produce a toolpath anymore. Using Multi Axis Finishing, Fusion always tilts the tool the deeper the machine moves in the taper. The yellow lines in the screenshow correspond to the tilt of the tool. As the tool starts on the top, it is almost perpendicular to the part, but gets steeper the further it moves inside.
My machine has 5 axis, four of them are on the head, meaning the head does the X/Y/C/B movement. The table is the Z-Axis. There is plenty of clearance for the head and tool.
How can I create toolpasses where the machine does not tilt the tool to such extreme angles?
