3D contour wont follow selected chain
a_youssryAQBN2
a_youssryAQBN2
3D contour sometimes bugs out and starts cutting edges I did not define for it to cut where as using a 2d contour with the same chain selected behaves as expected.
Screenshot 2025-03-22 184051.pngScreenshot 2025-03-22 184004.pngScreenshot 2025-03-22 183836.png
a.laasW8M6T
Hi
that's because unlike 2d contour, 3d contour doesn't follow chains, you define a boundary and it machines everything inside the boundary.
if you want similar behaviour to 2d contour but for 3d curves you should use the trace toolpath
Andrew Laas
Senior Machinist, Scott Automation
a_youssryAQBN2
ok so if I want a to create a 3d contour for a tapered angle like the one here ( I edited the model from the previous images ). I choose boundary as pocket and selected the outer face. It seemed to work.
Screenshot 2025-03-22 205058.pngScreenshot 2025-03-22 204921.pngScreenshot 2025-03-22 204858.pngScreenshot 2025-03-22 205225.png
a.laasW8M6T
Hi
While that make work in this case, I think you may be misunderstanding how boundaries work for 3d toolpaths
If you can share that file we can demonstrate correctly how to select boundaries and some alternative methods of containing toolpaths, and alternative toolpaths to machine features like that
To share your file Goto File>Export>save as .f3d/.f3z
Andrew Laas
a_youssryAQBN2
it was a test model with just a tapered extrude with a hole inside it.
a.laasW8M6T
(view in My Videos)
Andrew Laas
